Re: Fan belt adjuster stuck
Posted by Janicholson on August 22, 2011 at 20:22:56 from (96.24.99.126):
In Reply to: Re: Fan belt adjuster stuck posted by Mark-Mi on August 22, 2011 at 20:12:37:
The belt should be loose enough to be pushed in a little more than an inch with your thumb pushing as hard as you can. If it is tighter, it will be too tight, and wear the fan/wp bearings. They do adjust, they are a pain. When freed up, put anti sieze compound on the threads. Jim
