Re: M and H fronts
Posted by Mike1972chev on August 23, 2011 at 03:33:00 from (75.149.81.173):
In Reply to: M and H fronts posted by P T Farmer on August 21, 2011 at 16:40:17:
Everthing that is important of mounting the front ends is different.Get the correct front end,and pass the incorrect one along to someone who needs it.They will be appreciative of it!
