Re: Can I bore scope stuck Farmall 400 diesel?
Posted by dej(Jed) on August 23, 2011 at 05:45:44 from (141.189.113.1):
In Reply to: Can I bore scope stuck Farmall 400 diesel? posted by Brenden806 on August 22, 2011 at 18:07:17:
If you could scope the engine, what would you see? The stuck is going to be on the outer piston surface where it meets the cylinder wall. Pull an oil sample out of the pan and if it shows green water, you will have major issues to deal with. Send the sample out for an oil analysis and if it shows metals get your check book ready because most everything will need to be replaced. Good luck.
