An IH sickle mower set per the manual will cut all day long if everything is in good condition. Everything from lawn grass to brush. If it is clogging it is likely out of adjustment/dull and/or one of the following is an issue:
No grass board to turn over the end of the swath can cause clogging up on the tractor end of sickle on the next pass.
Make sure you have the "one and a half" tooth at the end of the sickle. If not the sickle end will not clean itself under some conditions.
Depending on where you are, you may have a lot of dew down in the hay. A dull sickle will cut dry hay but a lot of moisture can clog the best of them. Watch your cutter bar and tires to see if they are wet when cutting. This is why we always mow after lunch here in August.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
