Posted by David Lampman on August 23, 2011 at 19:31:51 from (69.54.29.239):
In Reply to: Rust in tank posted by kopeck on August 21, 2011 at 18:21:34:
K, I just went through my tank after it sat for 15 years. When I first looked in it I was sure I would have to line it. It looked to me to be very rusty. But I tried that on an old Suzuki tank with disastrous results. Besides, there is a baffle in your tank (as you know) that I think would not allow you to get a good "flow" of the lining goo. What I did was to soak the tank with a gallon of lacquer thinner. (Don't forget to plug the hole in the bottom first :-))I swished it around every so often for 3 days. When I dumped it out I couldn't believe the crud that came out. It turns out that my "rust" (it really looked just like rust) was shellac from 50 years of gas evaporating. Then I used a commercial steam cleaner (not just a pressure washer, you need the heat) set at 300 degrees and sprayed the s**t out of it through both holes. When I look inside it now it looks like it's brand new. Hope this helps Dave
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
