Posted by chevy_cowboy on August 23, 2011 at 19:47:10 from (75.129.241.75):
In Reply to: Rust in tank posted by kopeck on August 21, 2011 at 18:21:34:
I've lined both of my farmall's tanks (B and H) with Northern Fuel tank liner. Stay far away from the guys that tell you you'll have to cut a hole in the tank to line a baffled tank, don't let them hack up a good original tank.
All you need to do is thin the liner material down about 20%, Northern recommends using MEK (Methyl ethyl ketone) or Acetone. Just mix 6 or 7 ounces into a quart of liner until its smooth, then it will be thin enough to flow past the baffles just fine. Just tape up the openings in the tank and tilt it all directions for a few minutes until you've coated all internal surfaces, then pour out the excess. To achieve the same thickness of liner, you'll need to do 2 coats of thinned liner.
The most important part is let it cure properly... most of the problems people have with fuel tank liners is they don't let it cure long enough before filling it with gas, and the liner dissolves. I let mine set for a couple days between coats, and a full week after the second coat before filling with gas.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
