Re: Super C Low compression
Posted by gene bender on August 24, 2011 at 02:21:30 from (67.55.226.80):
In Reply to: Re: Super C Low compression posted by hattrick on August 23, 2011 at 22:03:33:
Does it start and run? If it doesent start and run then maybe you havent set the valves correct.
