Re: Super A lower sleeve seal question
Posted by El Toro on August 24, 2011 at 04:21:21 from (108.15.86.54):
In Reply to: Super A lower sleeve seal question posted by David Lampman on August 23, 2011 at 18:45:46:
The orignal block sleeves would measure 6-7/8" in length and the od of the sleeve at the seal is 3.312". The sleeves in the 354898R1 block
measure 7-1/32" in length and the the od of that sleeve at the seal is 3-7/16". Hal
