Re: Farmall 44 H steering
Posted by John A. on August 24, 2011 at 05:33:33 from (76.1.122.180):
In Reply to: Farmall 44 H steering posted by Bo Mack on August 24, 2011 at 02:39:58:
Bo, Probably it is the 1/2 Moon key at the little universals joint under the hood at the support bracket that the steering shaft goer through. The steering shaft is spinning in one end of that little universal. Simply loosen all necessary hardware slide the shaft out of the female part, fine the keyway, drive out the remaining part, slide in a new one, reinstall shaft, tighten all hardware and you should be good. I doubt it there is a problem in the steering sector, but after 60+ years anything is possible. Hope this helps.
Later,
John A.
