Re: Super C Low compression
Posted by El Toro on August 24, 2011 at 06:07:25 from (108.15.86.54):
In Reply to: Super C Low compression posted by hattrick on August 23, 2011 at 21:49:32:
The engine may need a complete rebuild with new sleeves and pistons. First I would pull the head and either do a valve job or have your local auto machine shop to do it. Set the valve clearance at .017" cold. Hal
