Re: Super C Low compression
Posted by Wilks54 on August 24, 2011 at 06:11:53 from (216.207.2.99):
In Reply to: Super C Low compression posted by hattrick on August 23, 2011 at 21:49:32:
I'd check the simpler things first, like gaskets. Make sure they aren't leaking. If they are good, then get into the engine. I'd spray them good with some WD-40 or similar and let them sit overnight. Start her up the next day and see if the compression improves.
