Posted by JRSutton on August 24, 2011 at 07:05:20 from (75.130.109.233):
In Reply to: power loss when hot posted by sgtbull on August 23, 2011 at 18:39:53:
My first guess would be the coil's going bad. Check the spark before and during the problem.
Much less likely, but possible, would be a bad vent in the gas cap - but so easy to check that it's worth doing. Just remove it hen you're having the problem.
When the problem's happening - I'd play with the choke - half choke it, see if that makes a difference. If it does, you know you've probably got some fuel blockage problems in the carb. But that would be a coicedental problem since it doesn't really fit what you described. But again - a free, simple test.
I'd adjust the valves. a little less simple to do, but still free.
If the points/condensor's old, just swap them all out for the fun of it. But now you're spending money.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
