Posted by El Toro on August 24, 2011 at 07:56:08 from (108.15.86.54):
In Reply to: Farmall c value posted by Jacksonduper on August 24, 2011 at 06:45:44:
You need to pull a plug wire and see it there's any fire to your plugs. If there's no fire clean the points with some 320 wet or dry then check for fire to your plugs. If you have a distributor you need battery voltage for the engine to start. An easy way to check that is with your ignition switch in the on position and the points open you should have battery on both small terminals on your coil. Use a volt meter or test lite when checking for voltage.
If there's good fire to your plugs check your fuel system by disconnecting the gas line at the carburetor and see if there's a full stream of gas from the tank. If there's just a trickle your gas tank is dirty and needs cleaning and carburetor probably needs to soaked in carb cleaner and the jets blown out.. Post back what you find. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
