Re: power loss when hot
Posted by Janicholson on August 24, 2011 at 13:13:16 from (199.17.6.77):
In Reply to: Re: power loss when hot posted by sgtbull on August 23, 2011 at 20:44:05:
Gas percolation and boiling does happen. Putting a reverse flow fan that blows through the radiator can reduce cowl temps radically.
An electric fan on the radiator instead of the belt driven is very good, and saves HP.
Putting foil insulation blanket between the engine and tank can be very helpful. Insulating the fuel line with rubber tube split to fit over is also good.
A coil going bad can be affected by heat, and breakdown under hot load conditions.
Jim
