As it is tightened into the bore, be sure to noodle on it so it centers. Be sure to start with the jack screw almost all the way in, so it has full travel as it goes up and out of the top of the sleeve. Be sure it is sharp. Use a coolant lubricant like Tap Magic, or a mix of diesel and engine oil 50/50. to keep it happy. Do not remove more than the deepest part of the top ring groove wear. Honing to remove the remaining lip is done with a sunnen straight hone or equal. If the old pistons are used they might need to be resized by knurling to be usable if the taper is more than .003" on the diameter. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
