Re: Any tips or tricks on using a ridge reamer?
Posted by Allan In NE on August 25, 2011 at 02:23:36 from (148.66.88.254):
In Reply to: Any tips or tricks on using a ridge reamer? posted by sflem849 on August 24, 2011 at 20:10:09:
A ridge reamer is used merely to disassemble a badly worn engine and is pretty much a no-brainer as far as it's operation goes.
Make sure the cutting blade us below the ridge, lock it to the cylinder bore (it is self aligning) and then turn the screw to cut the ridge on it's way up; it's pretty much all automatic. The blade has a guide and it will only cut the ridge; no way you can make it "overcut".
Now, I sure don't wanna sound like a broken record here, but if you have a ridge in that cylinder wall that is bad enough to require the use of a reamer (about .010"), you need new sleeves, rings and pistons/wrist pins anyway.
Cut the ridge, hone it and just throw in a set of rings and I guarantee you that engine will pump oil like Haliburton and rattle like a diesel.
Allan
