Well, here is my $.02 worth. Anytime I clean up a bore (sleeved or not) that is within .005 +/- of stock, I use new rings. Rings really need to seat and wear in. If you use old rings and a honed bore, you may or may not get a good seat and wear in. More times than not, you won't.
You are absolutely correct, this is a diesel, and those are NOT as forgiving as the gasser. This is not a shot at anyone, but these engines in gasser config were low RPM, relatively low compression. Yes Virginia, the absolute BEST way is to replace everything, BUT, you can get good results if you don't replace the pistons/sleeves when using a bit of common sense.
I have honed, ridge reamed, and re-ringed quite a few engines over the years (without replacing the pistons and wrist pins), and because I stayed within certain limits for clearances and wear, they all worked and worked well. Anytime you have to make up more than +/- .005 with rings, you will fail......or at least be disappointed with the results.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
