Posted by Janicholson on August 25, 2011 at 09:37:26 from (199.17.6.160):
In Reply to: Re: H Charging posted by BTaylor on August 25, 2011 at 09:30:36:
The field coils should have a resistance (from the third brush to the F terminal) of less than 4 ohms, and more than 2.5 (IIRC) if it is out of this range, it will burn points if less, and not charge much if more. Compare the resistance to a known good generator of the same type if possible. There should be no connection to ground on that circuit if the third brush is lifted off of the armature segments with a plastic tab cut from a butter tub or such. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
