Re: Super C Low compression
Posted by hattrick on August 25, 2011 at 10:16:01 from (66.165.37.56):
In Reply to: Super C Low compression posted by hattrick on August 23, 2011 at 21:49:32:
So an update on this issue. I broke down and took the head off the tractor. The cylinders look good with very little ridge if any.The head gasket was coated with what looked like bathroom caulk. A white gummy coating. I am thinking that this could be the issue since I doubt that the gasket was replaced. The valve appear to be in very good condition but I have not really inspected that close yet. So would the cualk or head gasket axplain the 30ish pounds of compression? AT this point I would just like to get the tractor running. Since I soaked the cylinders with oil and the compression did not change I do not suspect the rings as the major problem at this point. Any suggestions other than try a new gasket?
