Re: 301 Gas Engine
Posted by Owen Aaland on August 25, 2011 at 14:36:08 from (216.47.33.55):
In Reply to: 301 Gas Engine posted by Allan In NE on August 24, 2011 at 05:18:53:
If you can't find the proper oversize pistons for your C301 you should be able to bore the block to accept sleeves and pistons for a C291.
In your other post you wrote that your engine was worn out with .010 over pistons. That should put your block at 3.822 plus wear. The C291 has a block bore of 3.8765 - 3.8775. It looks like boring your block another .050 plus and adding a counter bore would allow you to use the C291 sleeves and pistons.
