Re: Re: Re: Thinking of buying an H - any tips, pros or cons?
Posted by The Red on August 16, 2000 at 14:36:12 from (12.75.221.7):
In Reply to: Re: Re: Thinking of buying an H - any tips, pros or cons? posted by Pete in PA with followup question(s) on August 16, 2000 at 12:20:07:
Pete the liftall belly pump is the hydraulic pump that runs off a countershaft from the transmission. Sorry for any confusion. About the only real problems with the liftalls is that the drive shaft seal gets to leaking or the main gasket blows in the housing. Those are easy fixes. The pumps will wear with time but can be rebuilt without too much difficulty. They are clutch driven so when you depress the clutch it quits working. Cultivators, after market 3 points, front end loaders and sickle mowers with a lifting piston were common implements on an H.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
