Re: Anybody have just one WD-9 piston?
Posted by rustred on August 25, 2011 at 19:34:43 from (74.200.18.156):
In Reply to: Anybody have just one WD-9 piston? posted by sflem849 on August 25, 2011 at 19:00:51:
dont have a piston ,but was gonna say the sleeve taper is good for .013. even if you had .015 taper i wouldn't worry too much. give her a set of rings , and deglaze cyl's , dont spend a lot of time honing as your removing more meat.get her together and warm it up and then get her under load to get them rings seated. you'll be ok.biggest thing is run her warm even if you have to cover some of the rad.i have put just rings in some with a lot of taper and things went well. its not like it will be worked day after day.
