Re: TD-18A dozer compression leak
Posted by The tractor vet on August 25, 2011 at 20:05:48 from (76.212.235.251):
In Reply to: TD-18A dozer compression leak posted by Charlie Zuthke on August 25, 2011 at 12:33:27:
They USE to make shims to shim the sleeves up when you did and overhaul. You were suppose to use a depth mic and check the depth of the contour bore then mic the flange on the sleeve and shim to get the correct hight once the sleeve was PRESSED in . It has been many many moons since i was into a TD 18 engine like back in the early sixtys . Once i left the construction industry i swore i would never work on the big stuff again.
