Posted by John T on August 26, 2011 at 05:34:37 from (63.252.228.254):
In Reply to: positve grd. posted by Jim Pete on August 26, 2011 at 04:45:05:
Just the battery alone (no genny wired in) at Pos or Neg ground will power the ignition until it runs down (If its a mag it dont use the battery). If its a coil distributor ignition it performs best if the coil polarity matches the battery however.
NOTE BEFORE you re start the tractor with a genny connected, POLARIZE the genny so it matches the tractor polarity.
Most 6 volt came originally POS ground but a genny can charge at either polarity once polarized and if it has an ammeter its leads need swapped if you change polarity and likewise the coil as noted above
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
