Re: positve grd.
Posted by mkirsch on August 26, 2011 at 06:16:57 from (64.80.110.74):
In Reply to: positve grd. posted by Jim Pete on August 26, 2011 at 04:45:05:
Pos or Neg ground doesn't matter with a generator system.
All you have to do is like John T says... after you fix the generator:
1. Polarize it with the battery hooked up Neg ground.
2. Swap the wires on the ammeter so it reads correctly while charging.
If you upgrade to 12V and an alternator, you MUST wire the tractor negative ground, because the alternator has electronic components in it that are sensitive to polarity. Pos ground will fry most alternators.
