Posted by Bob And on August 26, 2011 at 07:21:28 from (72.100.25.22):
In Reply to: Re: 400 power steering posted by Janicholson on August 25, 2011 at 09:33:05:
concerning biggred's problem. I think it's possible to install the priority valve backwords. You might want to check that. My tractor's valve is held in place by a circlip, not a threaded plug. I guess I'll see if I can find the correct seal to fix my leak around the output shaft. If I can't I'll look for a char-lyn unit. They work better too. Thanks guys
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
