Re: 686 with a 2 point???
Posted by Erik Dekeyser on August 26, 2011 at 18:01:00 from (184.151.63.248):
In Reply to: 686 with a 2 point??? posted by Matt (NEIA) on August 26, 2011 at 17:16:32:
I have an operators manual for a 1979 686 and there is no fast hitch in there. It could have been changed because the fast hitch was avialible on the 656 which is the same tractor only older. I seen 2 686s sell at an auction this spring they went for between 8500 and 9200. The 686 will easily pull a 3-16s plow and a 12 ft disc. They are a great tractor if you buy it you will like it. Just make sure its a good one. Engine and TA jobs are not cheap.
