I was planning on dropping the oil pan come Monday and pulling the piston and sleeve out. Should not be to bad to pull. This engine uses wet sleeves and I have located a set of o-rings to reseal the sleeve. I did find a head gasket set but they sure know how to charge for them. I also was able to locate a new set of fire rings. I was thinking that I was going to look for factory made shims for a different engine, if they would be a little bigger I can trim the ends so they do not overlap. Thanks much, I'll keep you all posted as repairs progress.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
