Posted by Weldon K on August 26, 2011 at 19:18:02 from (173.189.222.5):
In Reply to: Jump Start an 826 posted by wolfman on August 26, 2011 at 18:42:22:
Your tractor has two batteries doesn't it? IH tractors have two 6 volts hooked together in series to make 12 volts. You say you hooked jumper positive to the right side battery positive (which goes to the starter). The positive post on the LEFT side battery is the one connected to the starter on those model IH tractors. Did you hook up to the positive( rear) post on the right side battery? It connects to the negative post on the left side battery. Connecting to frame anywhere is same as connecting to negative post ( the one with ground strap to frame) on RIGHT side battery. If you connected to the rear post on the right side battery I can't say whether anything was damaged or not, but you got it started.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
