Re: F-4 Magnetos
Posted by Tom Fleming on August 27, 2011 at 02:29:02 from (67.20.249.95):
In Reply to: F-4 Magnetos posted by Fritz Maurer on August 26, 2011 at 20:51:54:
Kirk knows his stuff and is correct. The iron bar used across both poles on a horseshoe magnet is called a "keeper". Yes, they do slowly lose magetism over time. However, as Kirk indicated, there are other things to check first. Points, condensor, and coil for starters. Although, if you are getting spark, but it is weak, coil is probably not your issue.
