Re: Farmall m Generater
Posted by rustyfarmall on August 27, 2011 at 06:44:36 from (216.248.71.224):
In Reply to: Farmall m Generater posted by Fritz Maurer on August 27, 2011 at 04:40:53:
You can't swing that generator out much more than about 1 inch before it will be rubbing against the hood.
