Posted by gene bender on August 27, 2011 at 19:13:23 from (207.177.56.151):
In Reply to: Re: Super A SAMPLE posted by David Lampman on August 27, 2011 at 16:35:44:
Thanks a bunch as my engine is on a B that used the hy pump and unit from a SA or C as i havent checked the part#s all i know they did a fine job made a new bat box then cut off the Bs steering post welded to the top of the batt box then used all the hy levers and throttle levers verry clean tractor not a dent anywhere was all painted long time ago reworked the mounts for the front mounted disc plow that was used on the SA. I have two AC planting units mounted on the front use the hy system to lift and lower works well for sweet corn patches.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
