Re: NOT GOOD[pictures] any body have one update
Posted by D Slater on August 28, 2011 at 04:59:55 from (184.15.50.93):
In Reply to: Re: NOT GOOD[pictures] any body have one update posted by ralph1111 on August 27, 2011 at 20:47:20:
All I can say is the housing 350303R3 was a cotton picker housing. housing won't work on a 460. Don't think the cotton picker axle was splined though. Can't help with the length, those tractors not common to my area.
Don't know if a international 560 axle would fit that housing since it has splines.
Also this could be a axle special to the manufacture of the fork lift, is there another ID tag other than the IH one on the tractor?
Suspect the axle housing was used on the forklift because of the mounting holes at outer end to attach some parts of the unit to.
In some cotton picker tractors the geared drops or offset housings are bolted to the end of housing 350303R3 and the weight carrying axle is in the drop. Not a splined axle in a regular tractor though. Does your tractor have the drop or offset housings, or does the axle come out of housing 350303R3?
