Re: international 990 haybine
Posted by Brownie 450 on August 28, 2011 at 05:18:03 from (66.43.241.198):
In Reply to: international 990 haybine posted by montanakid92 on August 27, 2011 at 14:31:43:
Good machine. If you want to keep the multi-rib flat drive belt in good shape, loosen the tension spring after use.
There are 2 grease fittings on the left side of the machine underneath at the rear that often get overlooked.
