Re: international 300 12 v wiring diagram with gen and ex...
Posted by SadFarmall on August 28, 2011 at 05:21:39 from (121.214.182.163):
In Reply to: international 300 12 v wiring diagram with gen and ext reg posted by chris m in tn on August 27, 2011 at 19:32:51:
All generator with regulator systems work pretty much the same.
The larger Main (or D) terminal on the generator goes to the Main (or D) terminal on the regulator. The smaller Field (or F) terminal on the generator goes to the Field (or F) terminal on the regulator. The Ammeter (or A) terminal on the regulator goes to the ammeter (-ve side if the machine is +ve Earth or +ve side if the machine is -ve Earth). If the regulator has an Earth or Ground terminal, this is connected to the chassis.
