Re: Cultivator for a B
Posted by gene bender on August 28, 2011 at 12:59:41 from (207.177.56.151):
In Reply to: Cultivator for a B posted by Bob on August 28, 2011 at 08:10:34:
Better check the lift levers as it could be one for the exhaust lift and unless you have the rest of the system you cant lift it up. There were two types of manual lift levers. One type had a long and a short lever side by side. The other had a lever both the same length one for each side. The third type for the exhaust lift had two levers side by side but had a pulley and cable with one spring to lower the lever assy. Both others had two springs mounted forward of the lever assy. Hope this answers your questions as to which type of lift assy the cult has. The lever assy could be used on all four models the b-221,b-236.b-238 the other model which it probably isnt would be the b-435.
