Re: Coil on '45 H
Posted by gene bender on August 28, 2011 at 15:32:41 from (207.177.56.151):
In Reply to: Coil on '45 H posted by Hillbilly_H on August 28, 2011 at 15:22:03:
You need to check the volts when the starter is enguaged you probably need to clean the ends or maybe a new battery. Your problem isnt in the coil try the volt test first. Maybe refreshing the starter will be the answer. New brushes and cleanint the commutator end along with bearings makes them pretty good
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
