Posted by John T on August 28, 2011 at 17:52:24 from (173.243.181.15):
In Reply to: Coil on '45 H posted by Hillbilly_H on August 28, 2011 at 15:22:03:
When the tractor is setting there the ignition points are usually closed so there is usually NO VOLTAGE on the coils output with respect to frame ground. With the ignition on and points closed there should be zero voltage on its output (to distributor) terminal but when they open there should be battery voltage present.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
