Re: Coil on '45 H
Posted by Janicholson on August 28, 2011 at 18:46:18 from (96.24.99.126):
In Reply to: Coil on '45 H posted by Hillbilly_H on August 28, 2011 at 15:22:03:
Probably a bad mechanical switch, Some are on the light bar, some on the front of the steering pedistal, and some are on the starter. If on the starter, the stud sticking up on the side of the starter gets worn and the contact that moves inside the switch fails to make contact. Some new switches still do not touch the stud when the switch is activated.
Most new push button switches are way wrong/cheeply made trash. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
