Re: Decals/ 400 TA
Posted by Janicholson on August 28, 2011 at 18:57:05 from (96.24.99.126):
In Reply to: Re: Decals/ 400 TA posted by Wardner on August 28, 2011 at 18:42:19:
With serious respect and a "you know that already", he said it slips in direct, not in reduction. The TA clutch (or possibly the master clutch) is the issue. If it slows down to TA speed under load, then goes back to direct when unloaded, it is the TA clutch. It could be radically out of adjustment as well. Jim
