Posted by Ron W on August 28, 2011 at 19:05:36 from (97.146.212.42):
In Reply to: F-4 Magnetos posted by Fritz Maurer on August 26, 2011 at 20:51:54:
Unless the tractor is complelety work out, it should start right up. The carb needs to be cleaned out, a wire run though all the holes/jets, and the float set right. If not, then you will crank until the cows come home. As for the magneto, make sure the IHC stamp on the magnet is facing out; otherwise the polarity is backwards. I usually have an old good sparkplug gapped out to 1/8". If it will fire that, then it will fire in the cylinder. As for magnet charging....IT MAKES A DIFFERENCE! I build a magnet charger so that I can charge all of my magnetos from now on after I service them. WHere are you located?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
