Re: international 300 12 v wiring diagram with gen and ex...
Posted by Janicholson on August 28, 2011 at 20:13:06 from (96.24.99.126):
In Reply to: Re: international 300 12 v wiring diagram with gen and ex... posted by chris m in tn on August 28, 2011 at 16:55:58:
If it is actually a generator with two bolt on terminals on the side, no diode is needed in the system at all. The Bob M diagram for a 560 gas will have the generator and regulator wiring you need (ignore the components not on your tractor. The 300 is much like a SH with the only real change being the starter relay instead of the manual switch. The wiring is the same 6 or 12v. Jim
