Yes the timing cover has to be removed as the seal goes in from the back. Like other post said you will need a puller to remove pulley and then some way to press it back. You also need to remove the steering sector as the pulley wont clear it. Thats why you mite want to get a speedy sleeve so the new seal has a good surface to seat.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
