Re: Super MTA
Posted by Ellis Kinney on August 29, 2011 at 15:20:11 from (74.130.194.205):
In Reply to: Super MTA posted by DK44H on August 28, 2011 at 20:00:22:
exhaust manifold repair. I have an M that had a wallered out exhaust manifold. Too far gone to rethread. I dressed the top of the manifold flat with a file. Bought a two inch pipe elbow and sawed the threads off with a band saw. I dressed the face of the threads flat with a file. I drilled eight holes around the dia. of the threads. 1/4 dia. Then I counter bored the holes for allen wrench type bolts. Next I drilled and tapped the exhaust manifold, made a gasket and put it all together. It has been holding up well and occasionally pushes a tree limb out of the way. This sounds a lot more complicated than it really is, and it is really cheap to do. Ellis Kinney.
