Re: Matching carb to manifold question
Posted by Janicholson on August 29, 2011 at 17:06:09 from (96.24.99.126):
In Reply to: Matching carb to manifold question posted by gurneejoe on August 29, 2011 at 16:04:10:
It will be fine. You should be on the lookout for a correct to head carb but the offset will be no issue with your intended use. Be sure to center things to prevent the chance of a gasket moving and allowing a vacuum leak. Jim
