Re: Front seal. Another stupid novice question.
Posted by Janicholson on August 29, 2011 at 17:18:40 from (96.24.99.126):
In Reply to: Re: Front seal. Another stupid novice question. posted by glennster on August 29, 2011 at 07:42:22:
Glenster is correct! The timing cover stays put the seal goes in from the front. The old seal can be removed with a slide hammer and flat hook, or sheet metal screws driven a little ways into the seal metal. Work it out from each side, not from one side only.
The speedy sleeve is a thin metal ring that slides onto the pully machined surface to cover the groove made by the old seal. NAPA, and places like Motion Industries have them to fit, Take the pulley and old seal.
It is also possible to purchase a seal that has a different thickness or lip location such that the seal rides in a different location on the pulley shank. Some of the pulleys come off with more than 4000 pounds of force. A stout splitter, or "U" placed behind the pulley is mandatory or the pulley will break. The shaft is a press fit, and can be polished some befor replacement to allow an easier install, but still a real press fit. not hand loose. It is retained by this friction. Jim
