Re: H Smoking
Posted by JRSutton on August 29, 2011 at 17:35:20 from (75.130.109.233):
In Reply to: H Smoking posted by james c. on August 29, 2011 at 11:51:55:
Black means you've got too much fuel/fuel isn't burning efficiently.
So you're either choked - your missing on one or more cylinders - or your're carb is set too rich.
If the engine sounds smooth, you're not missing...
Then make sure the choke is open all the way (don't assume the linkage is working properly).
If it's still a problem, try leaning things out a bit one the carb and you should be fine.
You may also want to check/replace your plugs if it's been running like that for a while.
