Farmall H
Posted by Jim Iowa on August 29, 2011 at 21:11:16 from (67.142.179.27):
I have an H that needs both belts replaced,however the hand-crank snout is pushed in and stuck so close to the crank pulley that it would be impossible to get a belt past it. i have tried soaking with penatrent, and using a pry bar. i cant get it to move. has anyone else experienced this and what did you do? thanks for your time. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
