Re: DT 361 misses out at low RPM
Posted by mkirsch on August 30, 2011 at 05:46:59 from (64.80.110.75):
In Reply to: DT 361 misses out at low RPM posted by Larry B 1486 on August 29, 2011 at 19:41:36:
Did you transfer the complete engine, turbo and all?
Without the turbo, wouldn't the pump be dumping too much fuel into the engine, causing the black smoke?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
