An injector that is stuck open could be causing your problem. With the engine at idle, crack the lines loose one at a time to see which one does not make much, if any, difference.
The injector that makes the least difference is most likely NOT the one that is bad. If you have an injector stuck open the cylinder that it is in is most likely firing, but it dumps all the residual pressure out of the injection pump head so that at idle all the fuel for the next cylinder in the firing order just builds the pressure back up so there is little fuel left to crack open the injector. At higher speeds there is more fuel injected so the miss will go away but that cylinder will still be low on fuel. Meanwhile the open injector will be dumping so much fuel that you can end up with a lot of smoke.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
